WTB: Narco Nav12 Connector and Manual
Have Narco Nav12 combined VOR Receiver-Indicator. Need the Connector block that slides into back, and the Install Manual.
This connector and manual from Nav11 may work too. If you have these ancient parts, much appreciated.
Ted
The nav 11 plug would work and I may have one in my old avionics shop test cable box somewhere, but I seriously suggest that you don't waste your time and money on it. When they were new they wern't very good.
The only difference in the anv 11 and 12 is the GS needle and flag and the channeling switch for the GS receiver (not included in the radio itself).
Run Forrest Run!
Even the later nav 110 or 112 are not much better and require expebsive boards to repair.
Invest in something better. If your goal is to get a GS receiver to fly or train IFR then even more important.
If you just need to fill an instrument hole and add weight I can send you a coverplate made of 1/2: steel.
JDB
