Results 1 to 7 of 7
Thread: fuel flow meter
    fuel flow meter
    Hello All,
    Is anybody familiar with the out of production fuel flow "Nav-Man" system? Rather than use a fuel gauge, I would REALLY like to use a system such as the "NAV-Man. To describe it, it doesn't read 'empty--------full'. It tells you the fuel flow in gallons per.,gallons used and gallons remaining, accessed by push buttons on the gauge. It's just like a computer (I realize that's denegrading to the flow meter, but...) it can't read your mind. So, you have to tell it how much fuel you put in, then it works off of that. What fuel you had remaining before you added more, you keep that figure in your head and use accordingly. Now. Isn't this all perfectly clear?
    Thank you.
    Steve
    Anymouse's Avatar
    2A2
    What you're describing sounds like a Shadin
    http://www.shadin.com/products/fuelflow/digiflo.html
    It's a pretty good product, but I'd still keep a fuel gauge though.
    Garbage in.
    Garbage out.
    Jim Hann's Avatar
    Before you decide to use a NAVMAN I would read through this accident report.
    http://www.cozybuilders.org/Glenn_Saunders/index.html
    Jim
    Jim Hann
    EAA 276294 Lifetime
    Vintage 722607
    www.mykitlog.com/LinerDrivr
    Fly Baby/Hevle Classic Tandem
    Navman
    Quote Originally Posted by Jim Hann View Post
    Jim
    Thanks Jim,
    but I'm not planning on using A Navman, they went out of business years ago. I'm still looking tho.
    Steve
    Thank you Anymouse, I'm looking into them now.
    Anymouse's Avatar
    2A2
    Quote Originally Posted by challenger View Post
    No problem!!
    I have both fuel gauges and totalizer (Shadin feeding a JPI) in my plane. I take the more pessimistic view of:
    1. My estimated fuel burn
    2. The fuel burn as indicatd by the Shadin
    3. The fuel gauge indication.
    I think you'll have a hard time getting even an experimental approved without a fuel gauge. If you want a totalizer as well, that's fine
