Thread: OpenAero sequence drawing software.
    The following note was posted on the news page of IAC.org today:
    OpenAero (www.openaero.net) Version 1.3.2 can now be set to print forms A, B, and C acceptable for use at IAC contests. Remember that all submitted Free programs must be checked, signed and dated by a current IAC Judge per IAC Rule 6.14, and that the competitor has final responsibility for the legality and legibility of the forms. IAC does not specifically test, approve, or endorse any sequence design or drawing software.
    Doug Sowder
    Feb 2013
    Balneario Camboriu - SC - Brasil
    Hi Doug, Do you know how to use the openaero.net? I'm trying to make the lines in bold style but I can't...I mean make the lines wider and darker...
    Quote Originally Posted by eagledriver.zoe View Post
    go to Tools/Settings/Expert - individually select both "Neg" and "Pos" and where it says "stroke-width: 1.5px", edit it to something larger - I usually go with 3px. Your next question will be how to make the roll text larger.....same settings area, select "rollText" and edit to a larger font.
    Feb 2013
    Thank you very much for your help, it worked...if possible, when you can I'd like to know how to enlarge the "figure elements" for exemplo a snap(the triangle is still to small) even when I enlarge the figure with the zoom feature the elements stay too small...thanks!!!
    Sorry I missed seeing your post earlier. I have used Alan Cassidy's Aresti program for many years, and have never really learned OpenAero or its predecessor, OLAN. I only posted here back in June 2013 to announce that IAC had determined that OpenAero's latest forms would be acceptable for use at IAC contests.
    Fortunately, Craig Gifford has it figured out, so if I ever need advice with OpenAero, I know who to call on!
    Doug Sowder
