Two new air speed indicators (front and back pit) 20 MPH difference through the ranges. Built a manometer. Pressure checked with both indicators blocked off, then tested one at at time. No significant leak downs. Manometer test indicated rear pit was accurate and front pit was slow. Is there any way to adjust a slow indicator? They are New Falcon air speed indicators.
Michael
N9648B
