Results 1 to 4 of 4
Thread: Which Battery to Install?
    Jan 2013
    Hello all,
    I own an S-LSA, and I think I'll replace the battery.
    Am I required to replace it with the same make/model/part# ? I have looked, and I don't see the same manufacturer or part# available.
    And if I do replace it with another one that's supposed to be as good or better, do I need a letter of authority for it? Or is using another battery one of those things that's okay?
    Thank you
    Jen
    Mike Switzer's Avatar
    Central Illinois
    Look at the pdf on this page & see if your aircraft is listed. I only use Concorde, our club has had nothing but trouble with Gill.
    http://www.aircraftspruce.com/catalo...deappchart.php
    Quote Originally Posted by eaajen View Post
    Hello all,
    Thank you
    Jen
    Jen,
    Whether you use a Gill or Concorde, the same size batteries are equivalent. It is generally who has the better price when you are ready to buy. Unlike Mike, I have had good luck with both brands for my customers. I have been converting my customers to the maintenance free batteries as they come up for replacement. A lot less aggravation. I highly recommend you purchase a Battery Minder for your new battery. I think you will find that your battery will last a whole lot longer than it did without one. One word of caution when using a Battery Minder if your battery is other than maintenance free, make sure your battery compartment has ventilation.
    Central Illinois
    I agree on the maintenance free battery - I use a Concorde RG-35AXC in our 182, I just bought a new one because some club members were getting nervous about the age, but other than being toward the lower end of the load test scale the 5 year old battery is fine.
