VOR antenna for glass airplane
Any recommendation for a VOR / Glideslope antenna for a composite aircraft?
http://www.rst-engr.com/rst/catalog/...e_antenna.html
cant get more simple or cheap.
RST antennas were on Voyager and dozens more. Continue the experimental theme... build your own. Super easy ! Put the $150 in your pocket. Yes, it is that simple.
I highly recommend Delta Pop Aviation for experimentals.
http://www.deltapopaviation.com/Home.html
Besides all the standard types of antenna, he also has specialize antenna for adsb and aprs.
Bob
