Results 1 to 10 of 19
Thread: First flight of my J4A since 1975
    Minnetonka MN
    N414K a 1941 Piper J4-A had its first flight Friday Apr 26 at SSQ, Shell lake WI, having last flown in 1975. The rebuild was started by others for the first 20 years, then I bought it over about 12 years ago. It has been upgraded with a "freshly overhauled" C-85 engine (put together but never run over 25 years ago), metal prop, Groves brakes, Ceconite cover & Randolph products, Cessna 150 mufflers, and a new cowl and baffling system. I removed the electrical system and put in a lite weight starter powered from a cockpit panel-mounted Piper APU plug & a ground based starting battery.
    The 20 minute test flight was done by Sandi Randall of Romeo Aviation, Cumberland WI. Now she gets to teach this 2000 hr 172 driver a tailwheel rating.Name:  FirstFlight 005A.jpg
    Check 6's Avatar
    Congrats! She is a beauty.
    Congratulations! Great to see a classic returning to the air! And have fun getting the tailwheel endorsement - to me, that's the most enjoyable and rewarding kind of flying there is!
    Hal Bryan
    EAA Lifetime 638979
    Managing Editor
    EAA—The Spirit of Aviation
    JimRice85's Avatar
    In a house with my laptop.....somewhere in Collierville, TN
    Quote Originally Posted by Check 6 View Post
    The plane or the test pilot/instructor?
    Jim Rice
    Wolf River Airport (54M)
    Collierville, TN
    N4WJ 1994 Van's RV-4 (Flying)
    N3368K 1946 Globe GC-1B Swift (Flying)--For Sale
    N7155H 1946 Piper J-3C Cub (Flying)
    Jun 2012
    The plane is pretty nice too
    Jul 2012
    Circle Pines MN
    Congratulations, that's a great looking plane and instructor. Once you get the endorsement, increase your experience in small steps. These planes are so light that any amount of wind has a huge effect on them, x-winds for example. Always know where the wind is coming from and what it's doing to you. Know the planes and your limitations and you should be fine. You're going to have a blast flying it.
    cub builder's Avatar
    North Central AR
    Congratulations. Having taught a number of pilots tailwheel in both the Champs and the J-4, I can tell you it doesn't get any easier than the J-4. You're gonna love that plane. It's well mannered and handles crosswind conditions better than many tricycles.
    -CubBuilder
    Apr 2013
    Congrats!
    I owned and flew a 1940 J-4A out of Brodhead, WI, for quite a few years. It's a very sweet (and highly under-rated) airplane. You'll learn to love it!
    Minnetonka MN
    The test pilot reported a temporary partial engine sag-off during an aggressive climb out. I have a cowl tank (~1/2 full) feeding a Marvel Schebler carb. Speculation is is a loss of head pressure. Has anyone else encountered this on cowl tank Cubs? THX
    Dec 2011
    "Sag-off" cause?
    Quote Originally Posted by nrpetersen View Post
    Yes, IMHO this might be normal with this powerplant. The plane was designed and built with an A-65 engine unless you have installed the specified wood prop and then you can install the C-85-12.... but I couldn't find anything other than the limited prop requirements.
    But anyway, it was not envisioned to be able to climb at the attitude the young lady (probably) was climbing with the C-85 (notably more powerful). There is also a possibility that the fuel line designed for the smaller engine, was not sufficient for the larger engine.
    I'm not an A&P, but I do have many hours in a J-4A (back in the '60's) and this may be a possible answer to the "sag-off" to which you refer.
    Hank
