Results 1 to 10 of 11
Thread: Old Lexan protective paper
    Jim Heffelfinger's Avatar
    Sacramento, California, United States
    I have a sheet of old Lexan sheeting and it uses a paper/thin film protector on both sides. I am unable to peel the paper off. I have tried http://www.aircraftspruce.com/pages/...eld/unmask.php
    It does remove the paper - one 1/2 square inch at a time and it skips a lot. Took several hours and 4 ounces to clear a 16 x 10 inch section of side window. Rough on finger nails as they are used to scrape the surface/
    Suggestions?
    jim
    Mike Switzer's Avatar
    Central Illinois
    When I was in college I worked as a detailer in a auto dealership, we used acetone to remove the stickers, etc from the windows. Of course that was glass, I'm not sure if acetone would react with lexan or not.
    http://www.palramhort.com/pdffiles/P...Resistance.pdf
    No to Acetone, btw don't get fuel or Windex on Polycarb
    MEdwards's Avatar
    Las Cruces, NM
    Have no idea if it's appropriate for lexan, but what about GooGone? It takes lots of stuff off.
    Central Illinois
    Quote Originally Posted by Jim Heffelfinger View Post
    Well, that would explain why the windows around the cashier down at the Quik-e-mart are so cloudy...
    Nov 2012
    I would try heat. A hair drier might work. If not something that takes bumper stickers off cars. Its kinda like a blow dryer but a little hotter.
    To remove the strip I put on the bottom of my windshield I use heat. It loosens the glue up enough to peel this strip back. Once removed I use glue remover on a rag and work off all the remaining glue.
    If this is on both sides you might only need to heat one side to get both side to peel off.
    Try Heat.....
    Nice to know it is resistant to cod liver oil and chocolate .... wouldn' you say?
    as usual try on a piece of scrap first....
    Have not tried goo gone or peanut butter.... YET !
    Minnetonka MN
    After putting on the goo solvent (I wouldn't use anything like acetone etc though) consider covering and sealing with aluminum foil taped around the edge to minimize evaporation, and let it sit for a day. You could try kerosene but I agree to try a small corner first.
    FA40
    Yeah, i have a suggestion. Ask the people who make the stuff how to clean it before you melt it or dissolve it.
    http://www.usplastic.com/knowledgeba...contentkey=573
    Notice they say you can use kerosene but not acetone, and windex with ammonia is....well, GO READ IT YOURSELF.
