Thread: Brake grease
    Bob Collins's Avatar
    Woodbury, Minnesota, United States
    Brake grease
    In his very excellent EAA homebuilder video on brake pads, Dick Kohler notes that the pins on which the Cleveland (in this case) brake assembly rides on needs to be greased with a "high temperature silicon brake grease." I'm unfamiliar with this and wonder if any of you have a particular recommendation.
    Many thanks!
    Bob
    New Hampshire
    I use anti-seize on the pins. Look at the label for the temp rating. Should be high enough. Has worked good for many years for me. If you inadvertently get some on the brake disk, clean it off before you are done.
    FA40
    I have used antiseize, too. but in response to this question I google-searched and found autozone checker etc sell EXACTLY that item, hi temp silicone brake grease, for a reasonable price. no hazmat shipping fee, it is in stock. how 'bout that!
