Just wondering what you use for the typical sealants and lubricants in your aircraft.
For example: fuel fittings, fuel gaskets on fillers, throttle cables, door hinges, pulleys, fuel tanks, aileron cables(chains), etc. Thanks.
Aviation Form-A-Gasket #1, Fuel Lube, LPS-2, LPS-3, LPS-1, Kroil. Not necessarily in that order.
DC-4 for oil filters and RADAR waveguide O'rings.
MIL-8802, PRC-8802, DTL-8802 for sealing fuel cells and around (military) antenna bases
Titeseal for older engine cases (unless the overhaul manual has been revised)
Weldwood contact cement for upholstery repairs
fuel fittings - hylomar
fuel gaskets on fillers - you mean around the cap on the filler neck? just the gasket
throttle cables - neverseize
door hinges - don't have a door, have a canopy
pulleys - don't have them
fuel tanks - MIL-S-8802 specification
aileron cables(chains) - don't have them
Thanks for your responses. Let me offer some more specifics in one area: Fuel tank with a threaded filler neck, sumps with gaskets, steel to aluminum fitting for fuel drains, and threaded aluminum to aluminum fittings for vent lines. Thanks again.
Not airplane related, but use silicon spray on your snow blower and snow shovels. You can't believe the improvement (of course you can restrict its use to around hangars etc)!
I never lube those. Ever. I do use gasket sealer on the threaded fittings.
