Results 1 to 8 of 8
Thread: Lubricants and sealants - unofficial pole
    Socal
    Just wondering what you use for the typical sealants and lubricants in your aircraft.
    For example: fuel fittings, fuel gaskets on fillers, throttle cables, door hinges, pulleys, fuel tanks, aileron cables(chains), etc. Thanks.
    Aviation Form-A-Gasket #1, Fuel Lube, LPS-2, LPS-3, LPS-1, Kroil. Not necessarily in that order.
    DC-4 for oil filters and RADAR waveguide O'rings.
    MIL-8802, PRC-8802, DTL-8802 for sealing fuel cells and around (military) antenna bases
    Titeseal for older engine cases (unless the overhaul manual has been revised)
    Weldwood contact cement for upholstery repairs
    FA40
    Quote Originally Posted by CAVU Mark View Post
    fuel fittings - hylomar
    fuel gaskets on fillers - you mean around the cap on the filler neck? just the gasket
    throttle cables - neverseize
    door hinges - don't have a door, have a canopy
    pulleys - don't have them
    fuel tanks - MIL-S-8802 specification
    aileron cables(chains) - don't have them
    Socal
    Thanks for your responses. Let me offer some more specifics in one area: Fuel tank with a threaded filler neck, sumps with gaskets, steel to aluminum fitting for fuel drains, and threaded aluminum to aluminum fittings for vent lines. Thanks again.
    Socal
    Bump
    Minnetonka MN
    Not airplane related, but use silicon spray on your snow blower and snow shovels. You can't believe the improvement (of course you can restrict its use to around hangars etc)!
    I never lube those. Ever. I do use gasket sealer on the threaded fittings.
