Originally Posted by
rwanttaja
Yes, but: What will the FAA do to mothball the facility if it's closed? Will they shut down the power to everything but security systems and minimal AC to keep the place dry? Wrap the consoles in plastic to protect them? Remove key equipment for common storage with that of other facilities being closed? If they shut off the power on March 2nd, what's the odds that it'll all power-up normally on July 25th? If it doesn't, will there be technicians/tools/replacement parts available?
