For a central stick (connected to the floor, between two legs) design, what is its longitudinal (forward-rearward) travel range? What is its lateral (left-right) total travel range? Is the center of a palm considered the grip point? What is a typical distance between its grip point and the longitudinal rotation center? What is a typical distance between its grip point and the lateral rotation center (which may be different from longitudinal rotation center) ?
