AC 23-8B - Flight Test Guide for Certification of Part 23 AirplanesI can state with some certainty that simply needing to record engine temps, etc. won't get you there.
http://www.faa.gov/regulations_polic...cumentID/74377
23.1419-2D - Certification of Part 23 Airplanes for Flight in Icing Conditions
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/cf3b88901453a59a8625730d006e4993/$FILE/AC23-1419-2D-Change1.pdf
That should get you there. It should also get you a request to have your head examined but then again, if we're going to test the design, let's freaking test it.![]()
