You should go take an hour of aerobatic dual to start to get an understanding of how "G", airspeed, and aircraft inertia interact.
But I will note that on final approach, you are unlikely to encounter 2G turbulence. That is really severe. Having a lot of experience with both sustained and momentary G's from flying aerobatics, I will offer the opinion that moderate turbulence is maybe +1.5G to -0.5G. And it is the minus G that gets folks most concerned. Getting jerked against the seat belts makes most straight and level pilots really uncomfortable.
Light airplanes float up and down more on final where airplanes with heavier wing loading, which means a higher approach speed, "punch" through a "bump" with less change to their flight path. But the airplanes with the higher wing loading typically stall at lower angles of attack! So what is going on? Due to the higher speed and higher weight, the time exposure to the "bump" is less and the greater inertia means that the airplane reacts less. In turbulence, mass and inertia are your friend.
