Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Harley engine on a sport plane
    Quote Originally Posted by Victor Bravo View Post
    The way I see it...
    If this is who I think it is: Great to see you're still around, Bill.....
    hogheadv2's Avatar
    Booger finger of the mitten
    Modern Harley engines are outstanding for reliability, most unmolested motors I have seen are over 100,000 miles before the top end / piston and rings are done. [These are not throttle rod bar jockey's] Harleys ARE Built With a chain drive speed reducer! Belt drives are a rage of after market and Race machines as far back as the 60's. With any aircraft repurpose engine a tear down and inspection is mandatory. Set up timely inspections for certain wear parts, ( maybe use gear drive cams to eliminate the timing chain) Cruise at 3200-3400 rpm all day long - every day.... at 100+ lb ft of tq at your crank, x 1.4 bdsr = 140 lbft , 75 hp at about 2800 prop rpm. Good baffling around the cooling fins, wrap the pipes in glass tape, (may want to relocate the carb to prevent icing [ airbox near the exhaust tube] http://www.aeroconversions.com/produ...arb/index.html This aerovee unit may be a replacement for your carb, unless your going HD fuel inj. If you look close a HD engine appears to be but just 2 cylinders of a Radial aircraft engine
    Mar 2013
    Los Angeles KWHP
    Wow... if you're remembering me all the way from those ancient days on RAH, thanks for the shout-out. Glad to see we're both still around
    Aaron Novak's Avatar
    Oshkosh, Wi
    Quote Originally Posted by hogheadv2 View Post
    If you look even closer, it is nothing like an aircraft radial at all. Keep in mind a motorcycle duty cycle and aircraft duty cycle are completely different. A typical full dress harley will use about 18 horse to cruise at 65mph. The knife and fork roller bearing connecting rod system in a weak link, and tapered pin crank does some downright scary things.
    hogheadv2's Avatar
    Why I continue to try to educate people.... The Twin cam uses a pressed round pin, That can easily be welded to the flywheels after they are set and balanced. Out of the Thousands of bikes and bikers I have associated with, I have never observed a properly set of flywheels move once set up. [improperly and too many 12 packs worked on them, a couple] ....... A Harley with rider has far worse aerodynamics than a brick! Go look it up. Touring bike 2 up with a trailer runs the hi-way hours on end, thousands of miles, year after year.... Far more load at cruise than a LSA.
    Oshkosh, Wi
    You are right, I was thinking of the pre TC cranks before the cost reduction of the pressed pin type. I always felt welding the cranks was a poor idea due to the carbon content of the parts and the relaxation of the press caused by heating. I just couldnt do it, I work with too many guys that worked in harleys engineering dept durring the TC "development" to ever feel comfortable flying behind one.
