Hello Everyone,
I have a One Design DR-107 with a Prince Aircraft P-Tip Wood/Carbon fiber Propeller. Was thinking it is pitched to fine and wanted input from others.
At WOT I'm getting: (verified off a digital tach & a/c tach)
Static- 2300rpms
120mph- 2700rpms- engine redline
200mph- 3250rpms- Vne
I'm sending the prop in for an inspection/overhaul and now would be the time to repitch if I'm going to.
The prop feels a bit draggy at higher speeds/higher rpms, and as my neighbors will attest it is quite loud!
Thoughts?
Russell
