Thread: Need to squeeze those big rivets?
    Tony Spicer's Avatar
    Jan 2013
    Wilmington, NC
    I needed to. When I decided to talk my way into being a Panther beta builder, the one thing I knew could be a stopper was a way to squeeze hundreds of 3/16" rivets. No rivet gun and no 3lb hammer for me. A bud had a 20 ton Harbor Freight press. I had a 2 ton bottle jack. Messed around with both, then decided to give building a squeezer a try. Requirements were that it could be built for under $50 (scrounging required), easy to use by one person, and set nice rivets every time. Off to Harbor Freight for a four ton bottle jack. Results here. So far, two sets of Panther spars without a problem.
    Tony
    CarlOrton's Avatar
    DFW Area
    Excellent photo documentary, Tony; I agree with the photo comments that you should document this with National. Very nicely done!
    Carl Orton
    http://mykitlog.com/corton
    Friggin' brilliant!
    vondeliusc's Avatar
    Kalispell, MT
    Tony's awesome rivet press
    If you have not been to his site, DO - great descriptions and what EAA should be..
    -Christian
    BushCaddy's Avatar
    Marshfield, MA
    Tony, great presentation and results. Thanks
    Don...
    BushCaddy N2C
    http://www.donsbushcaddy.com
    Jan 2013
    Wilmington, NC
    The HF squeezer is making the rounds of Panther beta builders. First set of spars in North Carolina. Second in Florida. Currently in Dick Fisher's shop in Youngstown, Ohio. So far, no issues.
    Tony
