Thread: 1979 Piper Arrow IV For Sale
    whatevrworks's Avatar
    Washington DC Metro Area
    I am putting my Arrow IV up for sale. Loacted in Stafford VA, price is $85500 or best offer. I'm making the move to a six place twin and don't have the support of the non-pilot monitoring (wife) to keep two airplanes. Full listing is on trade a plane if you search for the N-Number N625RS. Here is the link:
    http://www.trade-a-plane.com/detail/...V/1528922.html
    Below are copied and pasted specs.
    Feel free to call with any questions: 571-439-6410
    Airframe-1979 Piper Arrow IV PA28-RT-201
    -Serial#: 28R-791825
    -4720 Total Time on Airframe
    -No Damage History
    -Complete Logs
    -LOTS of Mods
    Engine
    -Lycoming 200HP IO-360-C1C6
    -Serial#: L-18785-51A
    -787 SMOH
    -Overhaul Completed 2005
    -New Slick Magnetos (2011)
    -Compressions during last annual #1-70, #2-74, #3-74, #4-70
    -Aeroshell 15W-50 With Camguard
    -Blackstone Labs Oil Analysis Every Oil Change
    Prop
    -Sensenich 2-Blade Aluminum
    -Constant Speed Prop
    -Serial#: 793728
    -572 SPOH
    -Overhauled 2007
    Avionics
    -Garmin 430 WAAS with Terrain Connected to Engine Monitor
    -King HSI slaved to Compass with Glideslope (Recently Overhauled Components See Remarks)
    -King KX-175B Nav/Comm with Glideslope
    -Garmin GMA-350 Digital Audio Panel/4-place Intercom (2011)
    -Garmin 327 Digital Transponder
    -JPI 700 Engine Monitor w/ fuel flow, fuel totalizer, oil temp, CHT/EGT, volts, OAT.
    -King Digital DME
    -Horizon P-1000 Digital Tach
    -Electric Standby Vacuum Pump
    -Airspeed Indicator with True Airspeed Scale
    -Astro Tech Digital Clock
    -Piper Altimatic IIIB Autopilot
    -Electric Trim
    -Pilot & Copilot Push-To-Talk
    Mods and Other Info
    -Knots2u Wingtips
    -Knots2u Gear Fairings
    -Knots2u Flap Gap Seals
    -Knots2u Aileron Gap Seals
    -Knots2u Stabilator Trim Gap Seals
    -Knots2u Stabilator Tips
    -Knots2u Baggage Door Cylinder
    -Pulse-Lite Recognition System
    -Champion Fine-Wire Plugs
    -Pilot AND Copilot Toe Brakes
    -Reiff Electric Engine Preheater (Cylinders & Oil Sump)
    -Planepower Alternator (2011)
    -New Brake Pads (2011)
    -New Main Gear Tires/Tubes (2011)
    -Whelen LED Wingtip Landing lights (2011)
    -Whelen LED Nose Landing Light (2011)
    -Whelen Wingtip Stobes (2011)
    -Whelen LED Nav Lights (2011)
    -Whelen Dual Rear LED Nav Lights (2011)
    -New Knots2u Wingtip Landing Light Lenses/Covers (2011)
    -Overhauled Remote HSI Gyro (2011)
    -Replaced Remote Compass for HSI (2011)
    -New Sandia SA-35 Remote Altitude Encoder (2011)
    -All Brake Hoses (Internal and External) Replaced (2011)
    -Dynamic Propeller Balancing (2011)
    -Overhauled Nose Gear Hydraulic Actuator (2011)
    -New Nose Gear Tire/Tube (2012)
    -Horizon P-1000 Digital Tach (Nov 2012)
    -Planepower Solid State Voltage Regulator (2012)
    -Overhauled Electric Fuel Pump (2012)
    -913.39 Pound Useful Load
    -200 Pound Rear Baggage Capacity
    -130 knots True Air Speed
    -9 Gallons Per Hour ROP at Cruise
    -EGTs around 1350
    -CHTs around 300
    -Very even fuel flows and temps EGTs are typically within 50 degrees for all cylinders which is something not typically seen without Gami Fuel Injectors.
    -72 Gallon Fuel Capacity or 50 Gallons to the Tabs
    -Uses 1 Quart roughly every 15 hours.
    -IFR Cert (Altimeter/Pitot-Static/Transponder) Completed 8/2011 - Due 8/2013
    -Annual Inspection Complete April 2012 - Due April 2013
    1979 Piper Arrow IV
    1970 Piper Aztec D
    Commercial AMEL/ASEL/IA/AGI
    Email: David.fill2@gmail.com
    Twitter: @davidfill
    Changed price and added cell number.
    1979 Piper Arrow IV
    1970 Piper Aztec D
    Twitter: @davidfill
