Results 1 to 4 of 4
Thread: BIG Homebuildt
    BIG Homebuildt
    So you think you are a pretty major homebuilder, maybe even put together a plane or two from scratch, with wood or tube frame or glass, not even a kit.
    But in the big scheme of things that is a drop in the bucket or in this case a splash in the ocean.
    A man in Holland has built an arc. That's right an arc, but not just a model, he built a full size replica of the real arc, assuming there was one.
    He researched scripture and got the size in cubits.
    His is 447 feet by about 105 by 75, and it took him 20 years to finish it. No word on how many, if any helpers he had.
    Shades of the Spruce Goose, except maybe no props.
    Dec 2012
    Ark -- mythical boat of the bible
    Arc -- portion of a circle
    wasn't sure what you were talking about until you mentioned cubits.
    You want to see a big homebuilt aircraft...check out the Concordia project on www.soaringcafe.com. I got to put water in it a few days at the world championships. What a glider...
    Vision401,
    I just wanted to see if you were paying attention.
    First step in building an ARK is to lay out the arc where the prow goes.
