two items... I too would check for seal leaks both at the cases, heads, intakes. See the Brian Carpenter home builder hints just published on eaa video re the 2 cycle engine. .
Next the Challenger needs much clearance for the prop. That is the reason there is such a tall belt redrive on a standard 503 installation.
