Need website help!
I'm trying to use EAA's event widget:
http://www.eaa.org/calendar/eventwidgetsearch.aspx
I'd like to add the event calendar to this page for 1k4:
http://davidjayperryairport.com/localevents.aspx
The website is hosted by officelive.com. When I enter the source code into the custom HTML popup box in the officelive.com website builder, I get the message below, and then the code doesn't work:
"To make script tags using the "src" attribute work correctly when using the HTML module, defer="defer" has been added after the URL."
I'm not sure if that is a clue or not.
Here is the source code I'm trying to use from the EAA widget page:
<script type="text/javascript" src="http://www.eaa.org/calendar/eventwidget.aspx?SearchState=&SearchCountry=&Chapt erKeyID=&Zip_Code=&Miles=200&MilesType=M&AirportID =1k4"></script>
Hi Steve. Try adding defer="defer" to your script.
<script type="text/javascript" src="http://www.eaa.org/calendar/eventwid...&AirportID=1k4" defer="defer"></script>
