Gday,quick note;I have used air staplers a lot,just be careful when passing from hand to hand,I have stapled myself on more than once. It is a moment of high anal pucker I can tell you .cheers Ross
Here is the p/n list for the Senco 22 ga staples: http://www.senco.com/tools/details-p...d-wire-stapler
Amazon lists them as well as numerous other online sources
Something I learned from a woodworker long time ago: Take a rack of staples where leg is too long and grind point off the legs with a belt sander or equivalent. Greatly lessens the likelyhood of splitting the capstrip as the 'flat' point crushes the wood fibers where a sharp point parts the fibers and causes splitting. Works great.
Also, if you plan to remove staples after glue is dry shoot them through some chipboard cardboard. They won't go in as deep and it's easy peasy to get the staples out by pulling up on the cardboard to loosen them up.
I got my stapler and staples from http://www.nailgundepot.com/. No connection, just a satisfied customer.
Here's the completed shipset
Regards,
Greg Young
1950 Navion N5221K
RV-6 N6GY - first flight 5/16/2021
1940 Rearwin Cloudster in work
4 L-2 projects on deck
