planes of short take off and landing, from Bert Rutan.
all of them have the scheme " tandem wing" (option of a rhombus of a boxwing)
if to connect Box Wing together with Wing-in-Ground, such flying device will turn out approximately
Design: Ikelos
By: Virginia Polytechnic Institute & State University, Loughborough University (UK)
Description: A team from Virginia Polytechnic Institute & State University and Loughborough University, United Kingdom took second place. Their joint effort resulted in “Ikelos,” an aircraft featuring a box-wing design with fans powered by a rotary diesel engine. This uniquely designed aircraft allows pilots to take super-short takeoffs and landings.
http://www.architectswanderlust.com/...stol-aircraft/
This unique design allows to reach super short takes off and landing.
The 24-person the design group consisted of equal number of students from Loughborough Department in aviation and automobile equipment and Virginia Tech's Department space … the group worked as virtual team throughout the most part of the project.
http://www.powershow.com/view/aa2db-...n#.T-N33Be2_kY
if to add below a wide wing, at us wing-in-ground with box wing will turn out
box wing-in-ground
bearing fuselage + box wing
bearing fuselage with a usual wing
bearing fuselage + box wing (box wing in ground)
sense of connection
airplane + WIG
consists in creating on landing a powerful airbag...
which gradually decreases and smoothly lowers our flying car before contact to a water surface
