Results 11 to 20 of 26
Thread: your thoughts on " Box Wing In Ground"?
    Jan 2012
    planes of short take off and landing, from Bert Rutan.
    all of them have the scheme " tandem wing" (option of a rhombus of a boxwing)
    Jan 2012
    if to connect Box Wing together with Wing-in-Ground, such flying device will turn out approximately
    Jan 2012
    Design: Ikelos
    By: Virginia Polytechnic Institute & State University, Loughborough University (UK)
    Description: A team from Virginia Polytechnic Institute & State University and Loughborough University, United Kingdom took second place. Their joint effort resulted in “Ikelos,” an aircraft featuring a box-wing design with fans powered by a rotary diesel engine. This uniquely designed aircraft allows pilots to take super-short takeoffs and landings.
    http://www.architectswanderlust.com/...stol-aircraft/
    This unique design allows to reach super short takes off and landing.
    The 24-person the design group consisted of equal number of students from Loughborough Department in aviation and automobile equipment and Virginia Tech's Department space … the group worked as virtual team throughout the most part of the project.
    http://www.powershow.com/view/aa2db-...n#.T-N33Be2_kY
    if to add below a wide wing, at us wing-in-ground with box wing will turn out
    box wing-in-ground
    Jan 2012
    bearing fuselage + box wing
    Jan 2012
    bearing fuselage with a usual wing
  6. #16
    Jan 2012
    bearing fuselage + box wing (box wing in ground)
  7. #17
    Jan 2012
  8. #18
    Jan 2012
  9. #19
    Jan 2012
    sense of connection
    airplane + WIG
    consists in creating on landing a powerful airbag...
    which gradually decreases and smoothly lowers our flying car before contact to a water surface
  10. #20
    Jan 2012
