Mike: This might give you some good ideas:
http://www.youtube.com/watch?v=4Ey5DHMYLZg
point to remember, these three way machines are a press brake, they are not bending brakes. they have their advantages but they will not do what a open bending brake will do.
Yea, I figured that out watching one of the woodward videos. All I have ever used is an open bending brake, I know it will do what I want. Some of the online reviews of the cheaper units are putting me off though. For something like my steel oil pan a few minor imperfections wouldn't be a big deal, but my fuel tanks & coolant tanks will be aluminum. I'm going to be using it for some other projects down the road also.
We have several box and pan brakes to choose from in different sizes and capacities. We also have Shear Brake Combo Machines that feature a apron brake and shear in one machine. Check all these machines at www.bodybuilderraceequipment.com
Yes, premium quality tools are a pleasure to work with, don't think anyone will argue that point. But there are situations where discount priced tools are functional and a good value when they will be lightly or seldom used.
I built an original design fuel tank for my Legal Eagle. It is a complex tank, lots of weird angles that must be correct for the thing to fit together properly:
http://eaglexl-58.com/tank-9.jpg
It was essential I have a bending brake in my shop for this project even though I seldom need a brake. The most practical option was an inexpensive Harbor Freight brake:
http://eaglexl-58.com/tank-14.jpg
This brake certainly won't win any precision-tool awards, and it requires some finesse and patience to get dialed in to get the results needed. But it worked well for the tank project and didn't bust the budget. Matter of fact, the price was low enough that even if I never need it again it was worthwhile for just the one tank project. Interestingly, I have used it several times since and I now consider it totally amortized and a useful addition to the shop.
The purists will sniff at these inexpensive tools, but that's ok, my Eagle fuel tank has been flying for two summers. The difference in cost between the Harbor Freight brake and a "better" one has funded the fuel for those two summers.
Sam, that same brake is available at our local farm store at a very reasonable price, and I thought about getting one, but there is no way to form all 4 sides of a box or pan without the fingers.
Did you just design your tank so it could be made 3 sides at a time & then fasten it together?
Each side is an individual piece. It was designed with external flanges so no rivets penetrate the tank. The simple brake easily handled all the bends and flanges. The crazy angles would have made for some ridiculously difficult layouts if three sides were one piece. Flamemaster sealant (same as used on RVs) was used to seal everything up and it has been leak-proof so far. More details here:
http://eaglexl-58.com/tank.htm
I disagree with you Marty. Harbor Freight is by and large cheap junk and while if it works, it can be a very good deal, TRACTOR SUPPLY sells top notch usually name brand stuff. I buy all of my airtools at Tractor Supply and it's a good deal. Sort of in between is Northern Tool if you have one near by.
