Results 21 to 30 of 45
Thread: Stewart Systems for Painting Aircraft
    The pictures, from my perspective, appear to have some form of contamination between the undercoat and topcoat. Since conventional solvents are not being used to get past any surface "oils" the surface prep is even more important.
    In the supplied photos - what type of spray gun was used? How long between fill coats and top coats and what was the environment during that time?
    Having seen the display aircraft that Stewart uses for their "booth" I was impressed. I attended two work shops on Stewart products - one observing and the other hands on. I was pleased with the ease of application
    I talk with the Stewart guys at almost every Osh and SnF and am tempted by their products. However, even they have what I'll call mystery problems from time to time. I was talking with the fellow who helps them and posts a lot on the SuperCub forum and asked about a couple of the covered samples he had on display at Osh two years ago and he said something like "Yeah, I had to do the yellow one twice. I painted it and it went to absolute crap, so I tore the covering off and redid it." When something like that happens to one of the factory guys and he doesn't have a good explanation, that worries me.
    Oak Harbor Wa
    you should get a trial kit and play with it.
    note that you can call them any work day ad talk to them.
    The builders who have gone before you are the best trial kit that you can have if you are trying to assess the quality and repeatability of a paint process. Sometimes a trial kit is usefull to assess your own aptitude for being successful, but that is a different issue than what is being discussed here....
    I do have (sort of) the trial kit. I bought enough stuff (including color coat) to cover a rudder - start to finish. Probably a project for a nice weekend when I don't have anything else to do. I'm expecting one of those in about 25 years. ;-)
    Oak Harbor Wa
    The original topic was ......
    ""Has anyone tried the Stewart System for painting? I have heard positives and negatives about it and would like to learn more from someone who has had any type of experience with it.""
    the best method of knowing that is try it see what ya think..
    Florida
    I recently finished a SeaRey (fabric) project. The Stewart system through the primer-filler was fabulous. The topcoat drove me crazy. I followed the company's videos religiously, even buying the gun that they recommend, and painted in a heated and air conditioned hangar. The problem was wide variation in results. Same gun, same environment, same operator, same technique.....the horizontal stabilizers came out very nice, the left wing looks good, the right wing is an embarrassment, etc. Now, all of this is appearance and pride, or lack thereof. The paint has coated the fabric and everyone including the DAR thinks that it is airworthy. But I'll never use it again. With only 35 hrs on the airplane, it's too soon to tell about longevity.
    Bruce
    Sep 2012
    Their newest top coat is EcoCrylic, a two part system. Anyone tried it?
    Sep 2012
    be very carefull with stawarts glue as it will release and turn to goo in a very short time if auto gas gets on it.
  9. #29
    Oak Harbor Wa
    Quote Originally Posted by Vetteman89 View Post
    Yes Don sent me a sample, it seems as good as the old DuPont Imron. but a little slower to dry.
    Their 1 part sandable primer is the best primer I have ever found. thins with water, cleans up with soap and water, and what you don't use goes back into the can.
  10. #30
    Matt Gonitzke's Avatar
    Wichita, KS
    Not to mention it dries in minutes. My only complaint about that is it can make it hard to clean the paint gun if you don't dunk it in a bucket of water immediately after spraying.
