Results 1 to 10 of 14
Thread: Help identify an old gauge?
    Slightly off topic, but you are the guys to figure this out.. it came in a box of parts...
    Its a gauge, nickel plated, about 1 inch wide, has a handle-slides into something. No way to connect it to anything-inductive, or set by hand only??
    Reads E...F on a scale. Looks aircraft? Came in a cardboard tube thats well worn, might be a test gauge?
    Help!!
    MickYoumans's Avatar
    KBXG - Georgia
    Looks like a gas indicator to me. E = empty and F = full.
    How about a shot of the bottom? Is there anywhere for a float or an actuating rod of some kind to attach?
    « Voici ce que j'ai fait...vous pouvez en faire autant! »
    "This is what I have done...you can do the same!"
    --Henri Mignet (1893-1965)
    cluttonfred.info
    NW FL
    Just a hunch with nothing to back it up, could be part of a test set to calibrate a fuel or oil tank.
    Here is a shot of the back. There is nothing to connect this to anything at all..
    Jim Hann's Avatar
    I'd also guess a quantity gauge, could a float rod that rotates belong in that hole in the center?
    Google "us gauge co" without the quotes and click on images, some neat stuff!
    Jim Hann
    EAA 276294 Lifetime
    Vintage 722607
    www.mykitlog.com/LinerDrivr
    Fly Baby/Hevle Classic Tandem
    Its not an actual hole... I can see no way to hook it up to anything... Just set it with the knob.. but, then whats the point? Ive been googling us gauge for days and other searches.. I cant find anything at all like it? Mystery.... for now
    Could it be pressure activated?
    Why not ask the manufacturer? http://www.ametekusg.com
    cluttonfred.info
    Good idea... I sent along an email, and some photos.. Fingers crossed. Not sure if it they have records, or the time to look into it, but we will see..
