Brock,
I apreciate the enthusiam. Using a unit head, cylinder and crankcase is nothing new. However it does introduce some complexity and loss of flexibility in design, especially in the prototype stage. You are going to need some equipment, and the knowledge and experience of how to use it. A medium size lathe is a must. The precision needed to fabricate a built up crankshaft is well beyond a drill press. I also sense a lack of familiarity with 2 stroke design....this is going to hurt you, and is a place to start educating yourself before you make a single chip or pattern. Unfortunately what you will find is that there are very few companies left that engineer and build high duty cycle high output 2 stroke engines. In fact I can only think of 2 or 3 in this country, so finding experts on the subject isnt going to be easy. I encourage you to follow your dream here, just be prepared for the amout of work it is going to take.
