Results 1 to 7 of 7
Thread: Looking to buy - Skyraider
    9G3
    I found this for sale in my neck of the woods, think its worth it? Anything to watch out for with this setup?
    http://www.barnstormers.com/classifi...Light+Kit.html
    Banned
    I don't know anything about this plane or if the price is right but if you are truly interested in buying it this rule applies to any aircraft type being considered: Identify and locate an individual in your local area who is expertly knowledgeable and familiar with airframe type and engine as well as building parameters/build quality. And then pay him/her to do a comprehensive pre-buy inspection. Good luck.
    9G3
    The builder is an A&P/IA
    Quote Originally Posted by joen6171b View Post
    think its worth it?
    nope.
    #1 is it's not finished and has never flown.
    Sam Buchanan's Avatar
    KDCU
    That may or may not be of much value. If the plane has never flown, this is most likely an A&P with no field history with a Skyraider.
    Regardless of the builder, I would want an independent set of UL-experienced eyes giving the aircraft a thorough inspection. Example, the copper oil pressure line is a no-no for me, but that is easily fixed. This might be a good buy but you need verification from an experienced builder...other than the owner. This assumes you have the shop skills to complete the aircraft.
    Happy hunting!
    Sam Buchanan
    The RV Journal RV-6 build log
    Banned
    It should not matter to you if the Pope himself built it. You require an unbiased, non-prejudicial evaluation. End of story. Take the advice being offered here and be much better informed and intelligent for it.
    9G3
    A friend of mine purchased the airplane, he is a former skyraider owner. Looking forward to tinkering with it.
