Results 1 to 7 of 7
Thread: Flight Testing Experimental Aircraft - Resources?
    Cincinnati, Ohio, United States
    Question Flight Testing Experimental Aircraft - Resources?
    Folks,
    I'm building a GlaStar and would like to start preparing my flight test plan for first flight and my overall flight test program.
    I attended several of the Flight Test Forums at Oshkosh this year and it was mentioned by Charlie Lutz and Bill Posnett that a new initiative was in the works to provide improved resources for flight testing aircraft. Charlie mentioned some teaming between SETP, EAA, and FAA on this. I've dug around on the EAA Web site and Community, but cannot locate anything on this.
    Can someone point me in the right direction to get news on this effort and to be able to start following it?
    Thank-you,
    Howard
    GlaStar builder
    Anymouse's Avatar
    2A2
    Quote Originally Posted by hplevyak View Post
    Folks,
    Thank-you,
    Howard
    GlaStar builder
    First I heard of this initiative, but I like the idea.
    In the meantime, here are a couple of books I recommend to get you started...
    Flight Testing Homebuilt Aircraft by Paul Askue
    http://www.amazon.com/Flight-Testing...keywords=askue
    This book will take you from before the first engine start, to taxi test, first flight, envelope expansion and stability tests. Unfortunately, it barely mentions performance testing.
    Understanding Performance Flight Testing: Kitplanes and Production Aircraft by Hubert Smith
    http://www.amazon.com/Understanding-...s=Hubert+Smith
    This book glosses over the stuff that Askue covers in detail. However, Smith does do a great job of explaining how to do performance testing and crunching the numbers with provided spreadsheets. You'll need to modify the spreadsheets a bit to match your application, but it's nothing overly complicated and will be worth the effort.
    Good luck!!
    Tustin, CA
    Flight Test
    The FAA has an advisory circular AC90-89A that covers flight testing of experimentals. This is a good place to start. Here is a link: http://www.faa.gov/library/manuals/aircraft/media/ac90-89a.pdf
    The recent NTSB study on E-AB safety mentions flight testing, lending impetus to more effort in this area. The Homebuilt Aircraft Council has been working on this for some time and hopes to do more with this in the future.
    Check 6's Avatar
    Chad Jensen will be presenting an EAA webinar on September 19 on this same subject.
    Sign up here: https://www2.gotomeeting.com/register/184622242
    Marietta, GA
    The flight advisor program was designed with this type of situation in mind. Try to reach out to a nearby flight advisor. EAA publishes a list by state.
    Aug 2012
    Abingdon Va.
    Flight testing exp. Aircraft
    :DHello Howard
    I did a webnar for EAA in the spring of this year titled "First Flight". It is in the Webnar archives on EAA. It got rave reveiws and may serve you well in preparing for the great day. Good Luck!
    Johnny White
    Aviators Unlimited
    rv8bldr's Avatar
    Pakenham, Ontario
    My buddy Kevin Horton is a professional test pilot for Transport Canada (and an ex-military test pilot). He has put together an excellent web site on his RV-8 build, but the Flight Test Links page is especially useful. There are all kinds of links to various flight test sites, articles, books, etc, as well as his own material. You might want to check it out. It is NOT RV specific.
    http://www.kilohotel.com/rv8/phplinks/index.php?&PID=1
    Mark
    EAA 367635
    President EAA 245
    1979 Maule M5-235C C-GJFK
    RV-8 C-GURV (Sold)
    Bearhawk #1078 C-GPFG (under construction)
