Results 1 to 10 of 34
Thread: South 40 - 2nd class treatment
    Marietta, GA
    "If" that's the case, they need to install more. Push more airpanes off the field if necessary because they can't generate that kind of cash. And with that kind of income, Helen should get her powder room in the S. 40, decorated with imported ceramic tile. All without raising fees or charging more for camping or a bottle of water.
    Going with that line of thinking, let's just turn the entire flightline into high rise condo's. It worked along the beach on the Gulf Coast, so why wouldn't it work at Osh?
    Banned
    Won't work....have to be timeshares as only needed one week of the year. The other 51 will be very boring!
    Cary's Avatar
    Fort Collins, CO
    Just to make it clear about the "move from the taxiway" issue, I was sitting in my chair about 5' inside the line drawn by the row numbers, I had been there perhaps 2 minutes when I was asked to move, and there had been no aircraft using the taxiway going north for more than half an hour; all aircraft had been going south on the other half of the taxiway because north-bound aircraft were being turned into the camp area long before getting to the row I was in. It's not a big deal, just an unnecessary intrusion.
    I think what annoys me the most is the disparity in facilities from one area to another. Almost anywhere on the south side of 9-27 of the North 40 has adequate facilities reasonably spaced, but almost anywhere on the South 40 or the north side of 9-27 of the North 40 has inadequate facilities. We all pay the same to camp there, so we should all receive reasonably similar facilities. Alternatively, if we're in the "Section 8" part of the field, we should get a discount.
    Cary
    Chad Jensen's Avatar
    Oshkosh, WI
    Facilities around the grounds will continually be upgraded as the funds are available. Shower facilities are insanely expensive, and adding them all at once is impossible without borrowing money. Paid for showers are much preferred, and as EAA is able, they will be installed. We know they are needed, and we have a "planning and zoning" meeting four or five times a year to go over sight plans and visions for each area.
    It's coming...but no matter who gets what when, someone will not be happy. We know that, but we can't do it all at once.
    Chad Jensen
    EAA #755575
