Results 21 to 30 of 54
Thread: TIG Welding a Fuselage-Insight needed
    AllenR's Avatar
    Boca Raton, FL
    Hey Neil:
    The Skybolt is on its gear but in my hangar in N. Fla while I live in S. Fla. Still trying to sell my house in S. Fla so I only get to the hangar once a month for a couple of days. This has been going on for the past 5 years. When I'm up there I work on it, when I'm down south I work on my RV9A which is closer to completion. I don't recommend working on 2 planes at the same time to anyone. On top of that, from 2006-2008, I worked at a shop and restored 2 Stearmans and a Great Lakes. My RV is almost ready for paint.
    Allen Rice
    Skybolt
    RV9A
    Pietenpol
    It would be nice if Aaron or someone else would take Charlie's pictures and mark them up to show where the problems are. I can see that they are a little bit rough but they look about like mine. I know what really good pro welds look like, especially when done on stainless tubing and pipe. They're really pretty, almost like someone put them on with caulking gun. But what I'd like to see is what an acceptable aircraft weld looks like even if it is not a near-perfect professional weld.It would also be nice to review the sequence for the welds in a cluster so that distortion in minimized.
    Aaron Novak's Avatar
    Oshkosh, Wi
    Quote Originally Posted by chintonmd View Post
    Actually I had hoped to do exactly that and mark up the pictures, unfortunately photoshop was not working for me and I was running out of time ( as usual ). However this might be a good lead in to homebuilt aircraft welding 201 webinar type deal.......who would be interested?
    AllenR's Avatar
    Boca Raton, FL
    Webinar sounds good to me.
    Allen Rice
    Skybolt
    RV9A
    Pietenpol
    Jeff Point's Avatar
    Milwaukee
    +1 on the webinar.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    ...including how to grind stuff down for a "do over."
    Not that I could do one jot better, mind you - I think the statute of limitations on welding skills has long passed for me! Happily, my plane is all tube and gusset for that very reason.
    I don't know about tons and tons of practice being needed. When I was learning to weld a looonnnnggg time ago the Ag teacher had me run beads down some flat stock in straight lines about four inches apart. When I could make a decent bead that way it got a lot easier for angles as curves, since I knew not only what right looked like, but what it felt like to make it.
    Neil's Avatar
    Monroe, LA
    I think you should do it Aaron. I can always learn more, and welcome the opportunity to do so.
    Sirota's Avatar
    Tucson, AZ
    I'd LOVE a webinar on welding
  9. #29
    I would definitively like to see more articles about Tig welding in Sport Aviation magazine. I've found some good info on the Miller site; http://www.millerwelds.com/resources/articles/Best-Practices-for-GTA-Welding-of-4130-Chrome-Moly-Tubing.
    I would also enjoy reading the TIG welding procedures and inspection criteria used by a tube and fabric aircraft manufacturer such as American Champion. Everything that I've read seems to be in agreement concerning joint preparation but there's very little about what is good enough, what is acceptable and factors such as penetration. Thanks for sharing Charlie and getting the conversation started.
  10. #30
    Likewise, as a very novice welder, I would love to have that information as well.
