So I read it's up to the builder to determine gross weight/ usefull load of the aircraft he builds and uses the manufacture for a guide line. If I build and list it over 1320 lbs then this would eliminate it for a sport plane? But if I list it lower, say 1310 lbs max take off weight, and I have a bad accident and they can prove I should have known it was over weight, I don't think my insurance would cover any liablity?
So the question is, does the home builder list the gross weight of the airplane? thanks
