Is it permissable to fly my Chief with the doors off. Everyone seems to skirt around this question. I think it would be great for summer flying!
The Chief is a model 11 right? If so, the TCDS doesn't say that you can. I didn't look for an STC, although I believe there is one for the Champ. Here is the link:
http://rgl.faa.gov/Regulatory_and_Gu...FILE/A-761.pdf
Jim Hann
EAA 276294 Lifetime
Vintage 722607
www.mykitlog.com/LinerDrivr
Fly Baby/Hevle Classic Tandem
Check with your local FSDO. My Cessna 180 has approval to fly with doors off and there is a long list of requirements for it that must be carried in the aircraft during operation with a door off., including number of passengers, maximum airspeed, having a safety strap across the opening, no slips, etc. You should be able to get a local FSDO to approve it based on the 7AC approval. Good luck though. Never try to outguess what the FAA will do..
Richard,
I just sent you a message.
Janet
All I can think of is Ron White doing his routine about being on a commuter plane with the pilot leaning out the window and telling a goose to "GO AROUND!!!!"this is the airplane the faa put an ad out on to check for bird strikes on the trailing edge of the wing after each flight...speed not a factor
