Thread: Radio frequencies at Airventure
    Jun 2012
    Toronto, Ohio
    Is there a listing of the frequencies used for the airshow durning Airventure? I will have a handheld transever while there and would like to listen in on the airshow performers..as well as other air traffic while I am there. I know I can get the arrival and departure freqs from the Notam..but need to know the airshow specific freqs.
    Thanks for any info.
    Wayne
    CJR / NC26
    http://eaaforums.org/showthread.php?108-Air-Boss-Freq
    Please make sure that you disable the transmitter on your transceiver if you're going to use a transceiver. There is nothing more disruptive to airshow operations than some yahoo with a stuck mike feeding crowd noises into the air boss frequency making it unusable.
    Jun 2012
    Toronto, Ohio
    FlyingRon, Thanks for the info and I have already devised a guard to go over/around the TX key!! I will make sure it is in RECEIVE only!! I know what a 'stuck key' or some 'dumbthumb' is like from others.. I definately dont want to be in that list.. Thanks again for the help..
