Results 1 to 10 of 10
Thread: make your parking boards
    its very dry at Oshkosh now--but if it rains--can be hell getting your bird out of its parking spot if the tires sink into the ground--picture below is a parking board that a homebuilder can easily make--3/4 inch plywood 10x18 with a bevel on one end.
    Kevin
    Marietta, GA
    I think mine are 1/2" or 3/8" - no bevel. They end up slightly banana shaped at the end of the week, but they do make the airplane easy to move.
    This could be a good project for the composite guys - design and build a really light, neato set of parking boards...
    below is a parking board that is good for all you spam can drivers
    1/8 inch diamond plate 10 x 18--note that the wheel block has holes in it so you can hold it down with tent stakes
    Kevin
    AND for all the flying clorox bottle pilots (cirrus and plastic kit planes)
    can be bought at Home depot and Lowes
    plastic down spout splash guard--runs around $7.00 each
    Kevin
    Marietta, GA
    Those are pretty spiffy!
    Eric Page's Avatar
    Toledo, WA
    Quote Originally Posted by Kevin O'Halloran View Post
    ...plastic down spout splash guard
    Now THAT'S ingenious!
    Eric Page
    Map of Landings
    Oklahoma
    Kevin,
    Here did you find that 10x18 diamond plate? Everywhere I call will only sell it in 4'x8' sheets ( for $180.00) and they won't cut them....
    Jordan
    AeroPilot's Avatar
    May 2012
    Lansdale, PA
    I know you can get some smaller pieces of diamond plating at Lowes and Home Depot.
    Quote Originally Posted by hkyplr18 View Post
    Kevin,
    Jordan
    A local firm that makes trailers has it--its scrap--he cuts it to size for me and only charges $25.00 for 3 plates
    I've gotten several sets for the pilots in B2OSH ( Bonanzas)
    where in Oklahoma do you live---leaving at noon for OSHKOSH !!!!!!
    Kevin
    Oklahoma
    Kevin
    Hey Kevin,
    I am down in Ardmore. Leaving Friday at 5am !
