Be careful. That spring affects the static and dynamic stability in pitch. It is not there just to hold the elevator up. Some aircraft use a spring for elevator trim. An example is the Aviat Husky, a newer design that includes an elevator trim spring. Some folks hate the way that a spring feels and for some airplanes, adding a spring can change the longitudinal stability.
N78Ps
