Avgas in the crankcase
Do to a malfunctioning float valve in the weber carb which sits on top of my Great Plains VW, 2180 cc engine, fuel has run into the crankcase. I detected it on preflight & did not start the engine, I imediately drained the oil and oil cooler. Does anyone have an opinion on any damage that may have occured to the internal parts of the engine such as the rod bearings, crank, etc.? I'm thinking (hopeing) it is probably O.K. since the engine did not run with the gas in the oil. Your thoughts please.
Thank you.
