Hello... I am a student at Embry Riddle, and I am working on a research paper for one of my classes. I am doing research on safety in general aviation, specifically, advanced technology built into new aircraft. I am presenting this exact survey to many pilot groups, including, but not limited to: Cessna Pilot's Group, AOPA, EAA, and others. I will gladly present my final paper to those that are interested. Please use the link below to take the survey, or you can copy the survey below, and paste it into an email to me at mcquillk@my.erau.edu Thanks in advance for helping me out, and please know that no names are required or needed on the survey, and no names will be included in the final paper.
Link to survey (easiest, and confidential way to take survey)
http://www.surveymonkey.com/s/JGZ5N3J
Confidential Survey
General Aviation Safety
1) Do you own or rent your primary aircraft?
2) What make and model aircraft do you fly most often?
3) Does your aircraft have any of the following equipment:
Glass Cockpit:_________
Auto Pilot:__________
Oxygen:__________
Pressurization:__________
Flight Into Known Ice:__________
XM Weather:__________
Airframe Parachute:__________
Turbo:__________
Synthetic Vision:__________
Traffic Warnings:__________
Terrain Warnings:__________
Electronic Flight Bag:__________
Airbags:__________
4) What ratings do you currently hold?
5) When was your Private Pilot Certificate issued?
6) Was your PRIMARY training done in the same type aircraft you currently fly?
7) Were you trained in spins and spin recovery?
8) Have you ever performed a spin and recovery as P.I.C.?
9) Do you use any type of tablet computer in the cockpit during flights? If yes, for what purpose?
10) Have you ever started a flight in conditions that you thought may be more than you can handle?
11) If you fly IFR with a glass cockpit, would you be comfortable making the same flights with an all steam gauge equipped aircraft? (Think of an aircraft with basic IFR package, from pre-1990).
12) Finally, do you feel as though you are always in complete control of the aircraft during ALL PHASES of flight? If not, why?
