Cave Man Stuff for your panel
If anyone is building a traditional 6-pack panel I have removed my vac pump with 500 hours on it, associated filter and pressure adjuster, artificial horizon and directional gyro.
Checked the vanes recently and the pump seems to be doing fine. The DG needs to be adjusted a few degrees every 40 minutes or so, sometimes less often.
Make offer, nothing reasonable refused.
Rik
