Experimental engines
Maybe someone can settle an argument........ If we put an engine with a log book that says it has been in a certified aircraft in an experimental homebuilt, it loses its status as a certified engine? It does not matter if the logs indicate that the only work done on it (inspections etc.) were done by an A&P? And what would be required to return it to service in my old Piper?
