Ok I finished two tables. Went with a 1 inch overhang on the front and back, and 2 inches on the sides. I added adjustable leg levelers using t-nuts and bolts with a locking nut.
I may add the retractable gear also. Here is a pic of the leg leveler hardware.
Thanks! This is my basement. The cabinet is actually an aquarium stand that I'm almost finished constructing. The long trim across the top front is still needed, and a shorter piece for the left side. Then stain and seal it. It's sized for a 120 or 150 gallon tank, the footprint of each tank is the same, the only difference being the height. The cabinet/stand is made from solid red oak, except for the inside bottom, which is red oak plywood. I don't own either size aquarium, so I'm thinking about selling the stand when it's finished. I had plans at one time to set it all up, but changed my mind.
I thought I would add this pic also. It's all the 2x4's for the support structure precut to size, ready to assemble, along with the hardware. However, the shorter leg doublers were cut about an inch long, with a final measure and cut just prior to installation. Same for the longer pieces of the lower shelf frame. I was shocked at the price of 3/4 inch MDF. Over $30 a sheet at my Lowe's. Becaue I made the tops oversized (64" x 26"), I needed two sheets of MDF. Total cost for both workbenches including the hardware, about $150, with some screws, 3/4 inch MDF, and a little bit of 1/2 inch plywood leftover.
I built from those plans but enlarged it some to 4'x8'. I very happy with it. You can see my build thread below.
http://www.homebuiltairplanes.com/fo...lots-pics.html
skeeter
I went ahead and added the retractable gear to my new tables. I modified the plans to use 3/4 inch plywood instead of the 2x4s. I used piano hinges and t-hinges along with the 2 inch full swivel casters. Works great! Seems to be strong enough. I had the plywood scrap already, so all I had to buy was the hardware. This brought the total cost for both tables to about $180. More than I wanted to spend, but these suckers will probably be around for 500 years!
Wow, i really like that wheel setup. Where did you get the plans for it. I'm going to be building a stand to hold my grinder, belt sander, band saw and scroll saw all in one. That's the perfect way to make it modile but stationary when you want it.
skeeter.
Here is the link to the retractable gear plans: http://www.eaa.org/sportaviationmag/1001/RetractableGear.pdf
Here is a link to the video showing the retractable gear in action: http://eaavideo.org/video.aspx?v=59403176001
Sonex flight testing complete. Building a Super Cub clone, check it out at www.facebook.com/piratecub
