Thread: Rand Robinson KR2 for sale in McKinney, TX
    Hi Guys! One of our long time EAA Chapter members has a Rand Robinson KR2 for sale in McKinney, TX.
    Check it out.
    Thanks!
    Smitty
    For Sale - Rand Robinson KR2. Fixed tri-gear. Aircraft is selling "as parts" only. Engine has about 100 hours on it. Everything on the airplane is working. Documentation and wiring diagrams for everything in the airplane will be furnished with each part.
    http://www.eaa1246.org/projectpics/13.jpg
    Parts List on the Aircraft:
    DAN DIEHL Landing Gear (Tri gear) engine mount - $150.00
    Engine REVMASTER (and engine mnt $205) - $3,000.00
    Wheels and brakes (3) - $300.00
    Engine cowl (custom) - $115
    Welded gas tank (22 Gallons) (custom) - $100
    Steel firewall $45, exhaust $295, gauges $292 -$632 for all
    Four in One exhaust pipe - $295
    Terra NAV Receiver (Serial No. 001310G) - $40
    FALCON GAUGE Gyro Horizon Electrical 14VDC (non TSO'd) Model GH02E-3, Serial GHE031352 - $500.00
    ACS PRODUCTS Throttle Control (Model A-820) - $51.00
    NIGEL REDDISH Stall Warner (UD? -V3RD 1402, 16(4)/250 T85) - $35.00
    AMERI-KING Emergency Locator Transmitter (ELT) (Model AK-450, Serial 466397) - $100.00
    KING KT-76 Transponder - $100
    AMERI-KING Mode C Encoder (Model AK-350)- $75
    FALCON GAUGE Altimeter (non TSO'd) MODEL NO. ALT/20INF-3 20,000 ft - $65
    UMA Vertical Speed Indicator (3-1/8" 0-2,000 ft.) $78
    PRINCE AIRCRAFT CO Carbon Fiber P-Tip Propeller (52" BT 48", Leading edge protectors) - $500.00
    UMA Airspeed Indicator (3-1/8ASI 40-180KTS) - $128.00
    Oil Temperature Gauge (2 1/4") - $42.00
    Precision vertical Card compass (PAI-700 14V) - $270.00
    Fuel shut off valve P/N - $29.00
    Collapsible Tow Bar - $46.00
    GARMIN GPSMAP 296 Americas, Ser. No. 67023208 (IOR-022492) with GARMIN 8.4V LI ION Rechargable Battery (P/N 011-00955-00) and GARMIN AC Adapter (Model FSV 120125UU15-1) - $300.00
    UMA Tachometer - $160.00
    ICOM IC-A200 Panel Mount Com VHF Air Band Transceiver Ser# 0117269 - $400.00
    Propeller - Edward Sterba Aircraft Propellers (Wood, urethane leading edge) - $300
    Spinners (2) One for each prop. 48.95, backplate 29.95, frontplate 23.95 (10") - $100.00
    ENTIRE AIRPLANE, AS PARTS - $5,000.00 - OBO
    CONTACT: Jerry Burchfield
    Email: frlt@earthlink.net
    Home phone: 972 396 1025 Cell: 214 477 6605
    Smitty
    Jul 2012
    Owner,VitalProductions
    waswonderingifyourKr2isstillforsale?
