Results 1 to 10 of 16
Thread: Getting final airworthiness certificate
    Dec 2013
    I bought a 2 seat kolb recently and it came with a special airworthiness cert. is this the permanent certificate or do I need a certificate that doesn't say special on it? Plane has 38 hrs on it. Also I found some paperwork that lists a specific area to fly in. Am I limited to that area? Thx for any input.
    Nov 2012
    This is used for the 40 hr fly off. Yes you are limited to that area that is listed on the forum or paper work. These are not like GA certified airplanes that have a 20-50 NM fly off area. On these you must keep them within the stated area's.
    Once this 40 hrs is flown off you will get your permanent certificate.
    Tony
    Quote Originally Posted by Mfly View Post
    It will always say special on it. What is the date of issuance? That is probably the permanent a/w cert.
    Yes, you are limited to that area until the specified test hr period is complete. That's called Phase I.
    Once the time is flown off, you make an entry in the records saying Phase I is complete and the a/c is controllable throughout isn't normal envelope, yada, yada, then you can fly anywhere.
    Nov 2012
    Marty thanks for the post. I could not remember every detail, its been to long.
    Tony
    Nov 2012
    I have a friend going through this now. Because of insurance he needs a pilot with so many hrs flight time. To make this short. This guy gets in this airplane that has NEVER been flown. Takes off and flies off. Out of site within mins. This airplane has a two stroke engine on it. Not that it matters but it does.
    I asked the owner or my friend what the paper work says for the fly off area. he said....does not matter he can fly anywhere he wants as long as he stays within 50 miles....WRONG... I tried and tried to get this man to understand, this just was not correct. I could not get this man to understand this.
    Get this..He is an A&P. I mentioned this to the man doing the test flying and you would think I mentioned I robbed a bank. I gave up and walked away letting them do what they want, for whom am I to tell this man with 1000 hrs flying or this A&P...They no not what they are doing...but they don't.
    Tony
    Nov 2012
    Tony
    You would have thought I was an expecting father waiting in the waiting room. I was pacing back and forth saying things like....I can't believe he flew off....I hope nothing goes wrong....I hope....I wish...
    the owner of the air park said things like...settle down...why do you care....shut up.....
    When he did finally return I just kinda stood there listening....First thing I heard...developed a fuel leak around 15 miles out, thought I better turn back....There's a puddle of fuel in the passenger seat....
    I mean no disrespect to these men. These men troll this site at least the owner does and he reads my posts. I hope he understands I only have his best interests in mind and those around me. I do not want to come off as a Know-it-all. I don't and will be the first to admit to this, but I will tell you if you are doing it wrong. If you hate me for it, nothing I can do about that.
    Tony
    Dec 2013
    do all kolbs have a special airworthiness certificate?
    Any Kolb that is built and registered as an experimental-amateur built aircraft has a special a/w certificate. They are not eligible for a standard a/w certificate.
    Yes, as Marty and the others allude to, the experimentals all have "SPECIAL" airworthiness certificates. The operating limitations may get amended (in the old days, now they just put the verbiage that releases you from the phase I restrictions after you've flown them off), but you are don't get a new certificate.
    Dec 2013
    Thx for replies, I got it figured out. After talking to fsdo , I learned that the phase 1 sign off was after 5 hrs and the plane now is in phase 2 and good to go anywhere but congested airspace. And there is no other certificate work to be done, the original special aw cert. is the final one.
