Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Materials for cockpit mockup
    Mike Switzer's Avatar
    Central Illinois
    I want to build a cheap mockup of my cockpit to check out seating angle, instrument location, control location, etc.
    Just wondering what you guys are using to build a mockup. I plan on building the finished plane with steel tube, I was going to build the mockup with cheap wood but the only straight wood I can find in sizes similar to what the tube will be are trim grade wood, and that costs almost as much as 4130. Most of what I am seeing that is cheap in the sizes I would use are filler & spacer stock which is so warped it is only suitable to start a fire with. I thought about using 3/8" plywood but it has gotten pretty pricey & none of it is straight either.
    steveinindy's Avatar
    Indiana
    Cardboard with a minimal PVC pipe and wood frame worked just fine for the mockup of my LSA cockpit.
    Central Illinois
    Was that strong enough to actually sit in? I'm not exactly small. I want to make sure the seating position is comfortable for longer periods, as I have some lower back issues, I figured I would sit in it out in the shop while I watch the ball game.
    Auburntsts's Avatar
    Tampa, FL
    How about particleboard or MDF? Around $20 for particleboard and $30-$35 for MDF (4X8 sheets), but at least it will be straight and not warped.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Central Illinois
    That is a thought. I might take a trip to the lumberyard later today. Too hot to be working outside, might as well be working on the plane design in the air conditioned shop.
    Central Illinois
    Oh, crap - I just realized my circular saw is up in the attic where I was working on putting down a floor. It is already close to 100 up there.
    My good sawhorses are up there also...
    Central Illinois
    Another thing I was thinking about was cutting a mockup out of foam insulation & gluing it together, not sure how well the seat back would hold up though.
    It would be a lot easier to cut out.
    If you have a table or radial arm saw, you can rip cheap 2x4s into almost any size you want. I make almost all my own moldings that way, far cheaper than buying trim wood and I get the sizes I want, not just what the lumberyard sells.
    Auburntsts's Avatar
    Tampa, FL
    Mike,
    Since you want to sit in your mockup, unless you are going build around something load bearing (like a chair), I'd stick to wood. YMMV....
    PP ASEL - IA
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Central Illinois
    Mike,
    I'm gonna look & see what my options & price are - I did find some 2" foam out in the barn that was left over from putting in the heated floor, I could use that as fill to keep the seat from caving in. (as long as it is sitting on the concrete floor)
