Page 14 of 14 FirstFirst ... 4121314
Results 131 to 138 of 138
Thread: Norm's Flying Boat UL Flight Test Progress
  1. #131
    Jan 2012
    Quote Originally Posted by Norman Langlois View Post
    New floats applied I hope the differences are all positive. The others originally tapered going aft then needed the upper 2 inch deck to have enough displacement to be stable. They became heavy,15#. These have more displacement and weigh less than 8# with the support frame , bare no fiberglass Attachment 7183Attachment 7184
    I like the rear float design with no bottom curved surface. It could possibly be improved with a step at the angle break. Keep that edge sharp, not rounded. Hope that works for you. If needed I can make further suggestions.
    Tell is more about the wheeled cart. Is it ground handling only?
  2. #132
    Norman Langlois's Avatar
    Northwood ,N.H. USA
    Jedi to answer your question. The cart is for ground handling. It can be used for launch. It was used for that in the beginning. It was three wheel then and was unstable with wind conditions.
    I use the special trailer for direct launch and the cart is used to move from the trailer to the hanger (garage)
    If Oshkosh 18 is made possible for me. I will need to bring the cart ,the launch trailer will not be there with me.
    On the float I hope no additional step is required.The floats will quickly be above water.
  3. #133
    Northwood ,N.H. USA
    Update . Things are not going as planned. I think Oshkosh is not going to happen. If I go it will be just as a spectator.
    The new floats are almost finished. I get my car back next week and maybe by the week after.Name:  left side  new flts.jpg
Size:  94.6 KBName:  new rr flts.jpg
Size:  90.6 KB I can get to the lake for a test flight. A little paint and out the door for inspection setup and run up.
  4. #134
    Northwood ,N.H. USA
    I have posted those new photos. I took care to center the camera level with the top of the floats and leveled out the airplane. The piece of conduit across show the relation . So I can see that they are almost at the same elevation as the older setup. I detect that the old setup may have had the lower tube brace dragging in the water when the plane jacked before on plane was achieved. This new setup is 1 inch higher and there is more displacement and should be above water even when jacked back fore the thrust up on plane.
    When the bow wave develops.There is a steep up angle this has not been a problem .I only hope with the increase of displacement. This does not result in a nose down drag by creating some incompatible relation to the main hull. This has been very tricky . I still don't understand why that after portion on the main hull was so important.
  5. #135
    Apr 2018
    Norm I have been reading all this and I am so impressed. My thought and its stupid I know, my wife uses a commercially built kayak that is maybe 11 ft long, poly something plastic and very tough and light. If a person was to put a internal keel/brace inside on the bottom and aluminum attachments like you have fab above and spray foamed filled. One of these floats on each side and these are made to flow very easily in the water. Just a thought and you already have these done.
  6. #136
    Northwood ,N.H. USA
    wmgeorge
    Thank you for your reply.
    Over the years many suggestions have been made. One notable was that round surfaces where not good for aircraft floats.
    I had round floats for the rear. They behaved very badly and thus I was told to pursue. shapes that had sharp edges and abrupt ends . as on a wing tip when air migrates to the top of the wing lift is lost. a similar bad happens the water also migrates around and this relates to a suction . From Jedi's post he suggests maybe a step. This would help reduce any suction.
    Putting aside these suggestions. I would like to make this point. I have been convinced in my own mind that ultra light aircraft ,having a low take off speed. Do not need to adhere to the strict requirements of heavy general aviation seaplanes. these need a much faster take off speed. that means a much higher hydrodynamic drag ratio. The multiplier is not linear with aerodynamic drag. The suction that hold the hull and requires steps and air induction in some cases . Is not as relevant to ultralight aircraft. I be leave the my craft shows this to be so. I once related my conclusion to the the weight shift that used a zodiac hull and still lifts off. Round sided and no step. It still lifts off,maybe not as well.
    Using a Kayak hull could fly . The FAA allows 30# exemption for each pontoon and 10# for each sponson and only 30# for a hull
    Even though the Kayak plastic hull feels light it probably weighs close to the exemption. The addition of foam and structure would make it undesirable. If the air frame weight even allowed this option.
    If I remember I started with a complete air frame weight of around 240# I realized I was not going to make a wheeled ultra light and deviated toward the seaplane. Removing all the gear structure nibbling away I have always been restricted from many suggested solutions because of weight. The use of more resin to smooth surfaces has always been out of the question since resin is very heavy again hydrodynamics are less of an concern because of lift off speeds. I have used resin and glass to seal out water and give the foam a thin skin .Also taking care to use less fiberglass and resin for structure. and using tubing instead. I also opted for solid core when I could .High density in combination with low density where possible. The high density for external glassed surfaces and low density internal. The main hull has a fiberglass spine, and contains no aluminum skeleton other than the air frame junction.
  7. #137
    Northwood ,N.H. USA
Size:  92.6 KB I threw some paint on them. It shows the water line in blue. These should work well now I need to get to the lake .
  8. #138
    Apr 2018
    Norm thanks for the well thought out answer. I figured someone you or someone else had already covered those float. Your work on this project is a pioneering step forward and I think you have done a great job of getting it airborne!
