Results 1 to 4 of 4
Thread: Kenya: Light aircraft hire w/pilot - Nairobi 2013
    May 2012
    Question Kenya: Light aircraft hire w/pilot - Nairobi 2013
    Hi!
    Can anyone supply relevant information concerning the possibility
    for hiring light 4 or 6 seater a/c by the hour out
    of Nairobi, Kenya, for safari flights in 2013-14?
    Thanks in advance.
    Harald
    - harald@olsen.dk
    - www.harald.olsen.dk
    Harald,
    You might try doing a search, or posting your question on the African section of Pprune - http://www.pprune.org/african-aviation-37/
    It so happens that my family and I will be moving to Nairobi this summer, so I can't answer you right now. It I should be able to provide some insight in the fall.
    « Voici ce que j'ai fait...vous pouvez en faire autant! »
    "This is what I have done...you can do the same!"
    --Henri Mignet (1893-1965)
    cluttonfred.info
    Check 6's Avatar
    Saint Augustine, FL
    Someone of this Africa aviation forum should be able to help you. http://www.flyafrica.info/forums/index.php
