Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Thread: AirVenture 2012 Streaming Media - Beta Testing Help Needed
    Hartford, WI
    Second round of tests. I'm looking at a single embedded player to handle all device types to simplify things even farther. If anybody is available to hit this link and let me know
    the following info that will be a huge help.
    Device: pc/mac/phone
    Operating system/version number of Device tested:
    Browser and version number:
    Internet connection used: Cable, DSL, cellular, something fancy your office has
    Time tested:
    Time zone tested from:
    Issues encountered:
    Thanks for the help.
    Paul Hayden
    I get a "We are unable to connect to the network" on the Firefox here at work. It's possible that it was blocked by the Textron corporate NetNanny. Does it use something other than the standard http/https ports?
    PaulDow's Avatar
    Connecticut
    Hi Paul
    It looks good, but as you say, there's not much motion although I did see a bird flying through.
    Device:
    I figured I'd try the most incompatible device I have. The HP Touchpad
    Operating system/version number of Device tested: WebOS 3.0.5
    Browser and version number: Default browser
    Time tested: Cable 1Mbps
    Time zone tested from: EDT
    Issues encountered: buffered a couple times, but only lasted about 2 seconds.
    Hartford, WI
    the PC/mac link should be a flash player stream it shouldn't have port related issues..but I'll look into it.
    Rick Rademacher's Avatar
    Urbana Ohio
    Using an I7 CPU with Win7 Pro and DSL at 4:40 P.M. EDT, I experienced a buffering message that appeared in the middle of the screen about every 2 seconds. Now, that would get annoying.
    Hartford, WI
    it is a 500K stream which worries me a bit. we might have to back that down. in the meantime I'll look into different buffer settings.
    MickYoumans's Avatar
    KBXG - Georgia
    Device: iPad 2
    Operating system/version number of Device tested: iOS 4.3.3
    Browser and version number: Safari
    Internet connection used: DSL
    Time tested: 6:20 pm. 5/7/12
    Time zone tested from: Eastern
    Problems encountered:. None
    Sirota's Avatar
    Tucson, AZ
    Hi Paul, Didn't have any trouble, the view poped right up
    Device:
    PC
    Operating system/version number of Device tested: Windows 7
    Browser and version number: IE 8.0
    Time tested: 4:00pm local, 2300 Z
    Time zone tested from: PST
    Issues encountered: None
    Device: PC with AMD Phenom Quad Core
    Operating system/version number of Device tested: Windows Vista Ultimate
    Browser and version number: Firefox 12.
    Time tested: 3:52 PM
    Time zone tested from: MST (never changes)
    Issues encountered: After one image, buffering dialog box appeared and application hung at that point. Have gone 10 minutes without an update.
    Want me to try Linux?
    Bill
    Browser and version number: IE Explorer (64 bit)
    Time tested: 4:04 PM
    Issues encountered: "We are unable to connect to the network. We apologize for the inconvenience," but www.discoveryworld.org loads OK.
    Bill
