Richard, I have not flown a Taylorcraft, but here is the way I have done it for other similar airplanes. First, find the stall speed, VSo. Now you can look in a book or ask another Taylorcraft pilot, but a better way and one that will be specific to your plane is to go up nice and high and do a few stalls. Find the power off stall speed, gear and flaps (if any) down, and remember the carb heat.
Let's say it is 40 mph, then your speed turning final can be 52 mph which is 1.3 x VSo, and not any more. As you get to the runway slow a little more to 48 mph or 1.2 x VSo. That should be adequate for control and allow a flare,but not have much float.
If you learned to fly in 172 or something with big flaps, this may seem strange to you, and take some getting used to. Just be careful, 800 ft is a very small runway, even for that light a plane. You may want to practice on a bigger strip first.
My Cub stalls at 38 mph, power off . If I drag it in with just a trickle of power, the stall speed is below the last figures on the airspeed indicator. I use 50 mph on final as 1.3 and make a full stall 3 point landing, no trouble stoppping in a few hundred feet after touchdown, with light braking, as the brakes are not much anyway, but at 30 mph and 750 llbs, not much is needed.
